  • Community
  • Q&A
  • Jira
  • Questions
  • How to create a JQL query to select issues in active and future sprints as well as Backlogged Issues
David.Newton June 11, 2021
I need some assistance writing a JQL query that needs to query the issues (i.e. Bugs, Stories) in my project's Active Sprints, Future Sprints and the backlogged items.
The issue I have encountered is getting the backlogged issues to show up in the query without have issues from closed sprints showing up.
the query I have right now (below) shows all issues in my project from all sprints that are open or are future sprints, as well as the backlogged issues, however, it does not show any subtasks or issues in those active sprints that have been marked as completed/done. I still need those to show up so I can create a report of sprint issue subtask statuses.
            "project = GLOB AND issuetype in (subTaskIssueTypes(), Bug, Story) AND resolution = Unresolved ORDER BY status DESC"
Any suggestions for what I need to modify to get the query to just display the issues and their subtasks from the active sprint, the future sprints, and the backlogged issue list?
Deepanshu Natani
Hi @David.Newton
The following query should work for you:
Project = GLOB AND sprint in (openSprints (),futureSprints()) OR project= GLOB and issuetype in (subTaskIssueTypes(), Bug, Story) AND sprint is EMPTY AND resolution = Unresolved order by created DESC
Lets try to understand:
JQL to get issues in current and future sprints: Project = GLOB AND sprint in (openSprints (),futureSprints())
JQL to get issues in Backlog: project= GLOB and issuetype in (subTaskIssueTypes(), Bug, Story) AND sprint is EMPTY AND resolution = Unresolved order by created DESC
David.Newton June 14, 2021
This appears to have solved my issue. thank you very much
Like Deepanshu Natani likes this
Andy Heinzer
June 11, 2021
Backlog issue are not in a sprint always, hence we need to account for those without an sprint field value at all in addition to those issues that are in an open sprint right now.  So try something like:
project = GLOB AND issuetype in (subTaskIssueTypes(), Bug, Story) AND resolution = Unresolved AND (Sprint is EMPTY OR Sprint in openSprints()) ORDER BY status DESC
Let me know if that helps.
Andy
Jack Brickey
Try…
project = GLOB AND resolution = Unresolved OR Sprint in openSprints() ORDER BY status DESC
