How to create a new project component and append it to Components issue field with Jira automation?
Michal Pasik
May 5, 2020
Issue.components smart value can be used for getting the components of an issue as a list. Is it possible using Jira Automation to create a new component which is not pre-defined in the project settings and add it to the list of already defined ones?
John Funk
May 5, 2020
Hi Michal - No, there is no provision in Automation For Jira to allow for the creation of a Component on a project.
