×I need to create isseus that have branching fields.
It means that if I choose field value A, thena I get next fields B,C,D.
If I choose field value B, then I get next fields E,F,G
In Microsoft forms it is easy
Hi Martin,
It sounds like you're looking to create some custom fields using the Select List (cascading) field type. Here are some links to help you get started:
Belto.
Hi Belto,
Cascading fields gives you two levels. I need custom number of levels
Martin
Also, different kind of fields and additional branchings
