Hi I need some help or advise on setting up a multi project board. my jira has 2 software projects and 2 jira work management projects. and when I try to create a board across these 4 projects, i am not able to select all of these four. I have jira adminstrator role. any advise on this is greatly appreciated.
Hi @Vamshidhar Gangu and welcome to the Community!
I don't know how you are trying to add projects to the board, but it should be possible to create a filter across your projects first and then use that as a source for your board.
Step by step:
Hope this helps!
Thanks for the steps. I was trying to select the projects from the drop down list but some of them were not showing up, especially those team-owned software projects. Thanks for the advise, i can select all projects using filters.
