How to define the comment field as required in workflow transition?
Patrick Roos
Hi there
How can I set the comment field in Jira Cloud as required in workflow transition?
Thanks for your help.
Kind regards, Patrick
3 votes
Fazila Ashraf
Hi @Patrick Roos
In cloud, the 'Field required validator' is available in the workflows.
You can use that and make the comment mandatory.
Patrick Roos
Hi @Fazila Ashraf
Thanks for your help. It works :-)
Regards, Patrick
Like John Funk likes this
Fabio Racobaldo _Catworkx_
Patrick Roos
Hi @Fabio Racobaldo _Catworkx_
I didn't need a 3rd Party App for my requirement. I added a transition validator "Field required validator" in my workflow transition - but anyway thanks for your help!!
Regards, Patrick
Kari
Hi @Fazila Ashraf
How can I set the Assignee and Comment field in Jira Server as required in workflow transition?
