Hi All,
I want to set a value of a component according to the linked issue. Let me give a scenario:
When I create a 'Test' and link it to a 'Story' (issue type), i should automatically set the component value of Story to the Test issue.
So, if issue 'ABC' (Test) is created with no components, and linked to Story issue 'XYZ' (having components as '123') during creation, then after the rules runs, 'ABC' should have component value set as '123'.
Here is the rule and I am stuck at the action part :
Waiting for you suggestions :)
Hello @Muhammad Jahanzaib Tariq_ T-6074
A problem with your current rule is that with branching the actions you add to a branch will be executed against the issues in that branch, not the trigger issue. From your description, in this scenario you want to be able to modify the trigger issue.
Do Tests get linked to more than one Story?
Do you have a unique link type that you use for linking Tests and Stories, or do you use a link type that may be used to link Tests to other issues for other purposes?
Hi Trudy,
Yes, in this scenario, I want to update the Trigger issue i.e. Test.
Tests will not get linked to multiple Story.
Right now, there is no unique link type that I will be using for this purpose.
Actually, I am using a plugin Zephyr and using the BDD feature of it. Now, BDD feature creates a Story first, then in that Story, we type a Scenario in it, which creates a Test. This is why I am using the 'when issue is created' trigger.
Now, when this test is created, it is linked to the story with 'relates to' link.
I have attached a screenshot for your reference.
Waiting for your help :)
You can copy the Components from the linked issue like this:
