How to enable list view to a project?
Pradeep Kumar Devarakonda August 22, 2021
How to enable list view to a project plan?
Nic Brough -Adaptavist-
August 26, 2021
Only certain types of project have that option, there's nothing to enable in the projects that do not have it.
Sarah Gruner August 26, 2021
Thanks for the info! WIll it be possible to modify the filters in the list view to filter for e.g. Components or Teams or any other column anytime soon?
August 26, 2021
Not that I know of, but Atlassian are developing new stuff all the time.
Too bad, would be really needed to efficiently use it for bigger projects.
Sarah Gruner August 25, 2021 edited
Have the same question. Can I enable the "list" view that appears in some of the new (?) project templates in e.g. a Scrum project?
August 23, 2021
What do you mean by "list view"?  What do you think is missing?
marc.jackson
December 14, 2021
the ability to edit straight from the list view itself. The Issues view you cannot edit from the view
Like • Anna likes this
