How to export and import request type from one jira instance to another jira instance?
Gurunathan Kanniappan July 5, 2024 edited
Hi Team
 I have a couple of requests in a request type group. I would like to export one request type from one jira instance to another jira instance. Kindly help.
Regards
Guru
John Funk
Hi Gurunathan,
Am I missing something? Why don't you just set up the Request Type in the other instance? Shouldn't take but a couple of minutes.
Gurunathan Kanniappan July 29, 2024
Thank you, John, that makes sense but just thought of asking if there is traditional way of exporting if we have more than 10 request types.
Like • John Funk likes this
Mohamed Benziane
Thank you, Mohamed. But I'm looking to export/backup "Customer portal Request Type" forms which we create. In case if the environment is refreshed from production or any other environment we would like to restore from the backup.
Aaron Pavez _ServiceRocket_
Hi @Gurunathan Kanniappan
Sadly you can't. There is no option to do that in the UI.
You can do it using API:
GET /rest/servicedeskapi/request
https://docs.atlassian.com/jira-servicedesk/REST/3.6.2/#servicedeskapi/request-getMyCustomerRequests
Regards
Aaron
Thank you, Aaron. I have never used or knew how to use an API? Do I need to use postman to export using this API? Any example video link or document will be helpful.
