How to export history in jira issues?
s vignesh
September 2, 2022
Yuliia_Borivets__SaaSJet_
Hi @s vignesh
Here is an article about how to export issue history via REST API or with plugins:
How to export issue history from Jira?
If you're okay with add-ons, check out Issue History for Jira. Here you can export issues changelog with 2 clicks (Excel or CSV).
It's easy to filter the list of issue you want to export history for.
The app is developed by my team. There is 30-days free trial, so you can check if it can help you.
Silas Forkel October 24, 2023
Dear @Rik de Valk , thanks for your answer on this!
How can i expand the changelog to get a full issue history? :)
I just configured some API Calls, so I'm not too much into it :D
Best Regards
Silas
Register now
