How to export issue typ with ID or something like that
Dąbrowski Damian October 19, 2022
Hi everyone,
I search solution and i wonder how to export all issue type with ID or something similar ?
Any solutions :) ?
Damian
@Jack Brickey  MY purpose is, i want to grab all issue type with ID.
Becasue, i need to my CRM system. I will be do integration with JIRA. The name of the request type is resolved by ID or GUID or some key which will allow me to identify the issue type ( in CRM)
Jack Brickey
October 19, 2022
Hi @Dąbrowski Damian ,
what do you mean by "with ID...". You can certainly export issues to CSV or Excel and include the Issuekey as well as any other field from the Advanced issue search. Can you restate your goal?
Jack Brickey
October 21, 2022
Please try the following....
  1. navigate to advanced issue search by clicking into the search bar where you will see this option.
  2. In the JQL box enter the JQL that results in all issues you wish to export, for example - project = abc. Where abc is your project
  3. Click on the export icon and select the option for CSV with ALL fields
check the results for desired ID.
