In my Jira namespace, while creating a ticket, there is a CustomField dropdown called Client which has some options as shown in the below image.
I am not able to find a way to fetch these options in the dropdown via JIRA REST API.
Can someone please suggest how to get it?
If you want to get all the allowed values for a custom field, use the createmeta or editmeta methods. Here is an example resource:
/rest/api/2/issue/createmeta?projectKeys=YOURPROJECTKEY&issuetypeNames=Bug&expand=projects.issuetypes.fields
Use the createmeta methods. you will get allowed options for all custom fields.
REST API url : /rest/api/2/issue/createmeta?projectKeys=<PROJECT KEY>&issuetypeNames=Bug&expand=projects.issuetypes.fields
@Nic Brough -Adaptavist- Thanks for the quick reply.
the id for the above client dropdown is customfield_12345
Can you pls tell how to retrive the fieldId and contextId so that I will use the same in the API call to fetch the field options?
Same place, but the line above is "issue custom field contexts". You might want to check "projects" in the same area.
You will need to use the custom field context calls, as documented in the link I gave, to get the context for the custom field you are querying the contents of.
