×Hey,
I want to fetch all the available fields for the issue in the specific project which information is actually stored as screen.
so I want to fetch all the screen attached to specific project, is it possible to fetch that information over the rest API?
what is the relation between the screen and project or how can I define that over Rest API?
Dear @Harendra Chhekur ,
this is a bit tricky - because there is no single REST function to do.
So long
Thomas
Is there any way to get 'screen scheme' associated with project in Jira DC/Server?
Prashant
Hey Thomas,
Getting the edit screen with your solution will not work when there is no issues in the specific issuetype/ project.
Is there any other way?
