How to fetch values using jira api
geethanjali sj August 5, 2021
I have an issue and need to fetch user details from that issue
Nic Brough -Adaptavist-
August 5, 2021
Which API and which users on the issues?
rest api
And i need to get user email id and display name
August 6, 2021
Sorry for the delay,
If you "get" an issue with https://docs.atlassian.com/software/jira/docs/api/REST/1000.824.0/#api/2/issue-getIssue  you'll see it feeds you all the fields back, and when the fields are user fields, it gives you "name" and "displayName".
Given the name, you can look up the email address and other stuff with https://docs.atlassian.com/software/jira/docs/api/REST/1000.824.0/#api/2/user-getUser
Like Petter Gonçalves likes this
Martin Bayer _MoroSystems_ s_r_o__
Hi @geethanjali sj welcome on the community. Can you share more? What user do you need? Assigne, reported or some custom field's value?
I need to get the user email id and display name
Ok, but issue can have following "user" fields
  • assignee
  • reporter
  • custom user picker custom field
so what user value do you need?
geethanjali sj August 6, 2021
Custom field
Register here ⬇️
