"customfield_123": {
"required": true,
"schema": {
"type": "option",
"custom": "com.atlassian.jira.plugin.system.customfieldtypes:select",
"customId": 123
"name": "Field_123",
"key": "customfield_123",
"hasDefaultValue": false,
"operations": [
"set"
"allowedValues": [
"self": "https://xyz.atlassian.net/rest/api/2/customFieldOption/1",
"value": "abc",
"id": "1"
"self": "https://xyz.atlassian.net/rest/api/2/customFieldOption/2",
"value": "pqr",
"id": "2"
I want to fill above field while creating issue using REST API in spring.
IssueInputBuilder issueBuilder = new IssueInputBuilder(projectKey, issueType, issueSummary);
issueBuilder.setFieldValue("customfield_123", 1L);
issueBuilder.setFieldValue("customfield_123", "1");
issueBuilder.setFieldValue("customfield_123", "abc");
I have used above variations and all giving the same error below.
Caused by: RestClientException{statusCode=Optional.of(400), errorCollections=[ErrorCollection{status=400, errors={customfield_123=Specify a valid 'id' or 'name' for Field_123}, errorMessages=[]}]}
What should be approach here?
Hi @Anshul Mittal -- Welcome to the Atlassian Community!
First thing, you might also want to look in the developer community for questions like this one: https://community.developer.atlassian.com/
Back to your question...and I have not tried this to verify...
That second parameter to setFieldValue() can be a ComplexIssueInputFieldValue, and so you would need to compose it as needed. Your custom field appears to be a single select field and so you would need to provide either the id or name attribute for selection.
