Sign up Log in
How to filter markers in Easy Agile Roadmaps
Natasha Langsdorf
December 16, 2020
With Easy Agile Roadmaps, we are using Markers to indicate milestones. Is there a way to generate a list of all markers? I've tried to do this with "markers" "milestones" and "filter visible issues" to no avail. Any suggestions you have would be great, and happy to provide more information if need be.
thank you!
caitlin_mackie
Hi Natasha,
You can access that information via the board properties API. Bear in mind you will need to change the instance and board id to your own. It will give you the title, start and end date in JSON.
https://<jira_instance>/rest/agile/1.0/board/<board_id>/properties/ear-markers
If you have any issues, let us know and we'll be happy to help.
Thanks and Merry Christmas!
Caitlin
Marketing Coordinator @ Easy Agile
Natasha Langsdorf
December 17, 2020
Hi Caitlin! Thanks for your response. I'm having trouble getting to the board properties API-- I get an error message that reads:
{"errorMessages":["The provided Board id or key is invalid."],"errors":{}}
Even though my board ID is correct-- I tried both the name and the key. Any other suggestions?
Thank you!
caitlin_mackie
Hi Natasha,
It could be helpful if you can share the /rest/agile/1.0/board/82/properties/ear-markers section ?
Otherwise if you have a look at this post it might be helpful.
https://community.atlassian.com/t5/Jira-Software-questions/How-do-I-get-current-board-Id/qaq-p/1403593
Let us know how you go!
Caitlin
December 16, 2020
Hi @Natasha Langsdorf  -- Welcome to the Atlassian Community!
I do not see a way to do that in their documentation.  As a customer using their product, you may want to contact their support directly to ask if this is possible:
https://marketplace.atlassian.com/apps/1215695/easy-agile-roadmaps-for-jira?hosting=cloud&tab=support
After they respond, please post the answer back here so others in the community can benefit from your learning.  Thank you!
Best regards,
