How to findout the Total Estimate hours or Story Points for a user for a given sprint?
Lakshmi Priya October 9, 2022
How to find out the Total Estimate hours or Story Points for a user for a given sprint?
Currently my board shows number of issues created for a particular user for a given sprint. Is there any way that we could identify the total story points of the stories for the current active sprint for a given user ? or
Is there any way that we could identify the total estimated hours of the stories for the current active sprint for a given user ?
Karolina Wons_SaaSJet
October 10, 2022
Hello @Lakshmi Priya
Here's a helpful  Time & story points estimation in the Pivot table use case. So you can try whether it helps you.
Regards
Yogesh Mude
October 9, 2022
I found one community question which has already been discussed the same, hope this will help you to get this done.
https://community.atlassian.com/t5/Advanced-Roadmaps-questions/Show-total-of-quot-original-estimate-quot-per-user-per-sprint/qaq-p/939701
@Sakina the configuration you mentioned is showed the estimation for all the users present in the current sprint and @Lakshmi Priya is looking for an estimation for each user for the sprint..
Thank you
Sakina
October 9, 2022
@Yogesh Mude  she can use user filter on board
Sakina
October 9, 2022
@Lakshmi Priya  you need to Configure Estimations settings on your boardimage.png
then you should be able to see Total estimates of sprint on your backlog
FREE
