Issue: The transition name when going from any status to "To Do" is listed as "To Do (2)."
Desired State: The transition name when going from any status to "To Do" should be called "To Do."
Steps to Reproduce:
We are using company-managed projects.
Any thoughts on how I can fix this? Thanks.
You will need to go to the workflow for that issue type and edit it. Find the transition that is To Do (2), click on it, and on the pop-up that shows up click edit. From there you can update the name of the transition.
