I have created a listener that fires when an issuelink is created.
I need to get the value from my Source Issue's Epic Link field.
I have to be missing something simple, because I can't get it to work. My code as it stands is pasted below, and my log just says "epicLink: Epic Link"
Can someone tell me how to get the value of that field instead of what I assume is the field name?
Thanks in advance
import com.atlassian.jira.event.issue.IssueEvent
import com.atlassian.jira.util.ImportUtils
import com.atlassian.jira.issue.index.IssueIndexingService
def linkMgr = ComponentAccessor.issueLinkManager
def cfManager = ComponentAccessor.customFieldManager
def issueLink = event.getIssueLink()
def sourceIssue = issueLink.getSourceObject()
def destinationIssue = issueLink.getDestinationObject()
log.warn ("issueLink: $issueLink")
log.warn ("sourceIssue: $sourceIssue")
log.warn ("destinationIssue: $destinationIssue")
// CHECK TO SEE IF THE SOURCE ISSUE ALREADY HAS AN EPIC LINK
def epicLinkField = cfManager.getCustomFieldObjectsByName("Epic Link") as List
def epicLink = epicLinkField.get(0)
log.warn ("epicLink: $epicLink")
I managed to find my own answer. The issue was that I only had the field itself, but not the value of the field on the issue itself.
the new working code to get the epic link value replaces what is under the comment:
// getCustomFieldObjectsByName() returns a collection. Appending [0] gets the first item in that collection, and since epic link can only have one value, we know this is correct
def epicLinkField = cfManager.getCustomFieldObjectsByName('Epic Link')[0]
// getCustomFieldValue is a method of Issue and needs a field object like we acquired in the above line
def epicLinkValue = sourceIssue.getCustomFieldValue(epicLinkField)
To anyone looking for things like this - the API documentation is here:
https://docs.atlassian.com/software/jira/docs/api/7.6.1/
It takes a bit to learn how to use if if you're not already familiar with these, but the answers are in there.
This can't be for cloud, right? I can't do any of those imports
Help us plant more trees
