How to get Issue data from API calls
Mayur Gaikwad_Tech PMO
I want to get data from Jira to my DB in local system. Using get issue APIs, I can get that info but it will be for a single issue at a time.
How would I know how many records needs to be fetched as data keeps on updating and adding on Jira site. Do we have a specific API call for that?
Ravi Sagar _Sparxsys_
February 11, 2023
Hi @Mayur Gaikwad_Tech PMO
You can retrieve it by performing search using a JQL or a filter.
/rest/api/latest/search?jql=filter=1234
I have explained this in a video.
I hope it helps.
Ravi
Prince Nyeche
February 12, 2023
Use JQL search API to get the number of issues available based on your search criteria.
