How to get all "issues in epic"
Johannes November 2, 2022
Hi all,
my filter - issuefunction in linkedissuesof ("issuekey in (Auftrag-XXY, Auftrag-XYZ)") AND type = epic - shows me alle needed Epic to several order.
Each epic has also al lot of "issues in epic" -> and this is I want to get.  -> a list with all "issues in epic"
thx for help
Hannes
Walter Buggenhout
Hi @Johannes,
It seems you do have Scriptrunner installed and you are trying to find results with enhanced search
I'm also not sure if I understand your question correctly, but if you want to retrieve all issues in the epics you found with your first query, you should be able to find them like this:
issuefunction in issuesInEpics("issuefunction in linkedissuesof ('issuekey in
(Auftrag-XXY, Auftrag-XYZ)') AND type = epic
 Hope this helps!
Register now
