  • Community
  • Q&A
  • Jira
  • Questions
  • How to get alter when the ticket change status,eg: changed status from in progress to code review
Renchuan Xiao October 18, 2021
For me, I need to track those tickets which just changed status from in progress to code review. But I can't add one in all tickets and track the status every moment.
It would be better if i merely can do this by making a filter. If not, it is still OK.
Many thanks in advance!
Ollie Guan
Hello @Renchuan Xiao ,
Do you need to trigger this notification in real time ? Or you can use the subscription to set up email notifications.
https://support.atlassian.com/jira-work-management/docs/work-with-search-results/#Workingwithsearchresults-subscribeSubscribingtoyoursearchresults
JQL:
status changed FROM 'in progress' TO 'code review'
Renchuan Xiao October 19, 2021
Hi @Ollie Guan ,Many thanks I have succeed to track the change, but I want to order by the time when the ticket changed the status from 'in progress' TO 'code review'.
I don't know how to write JQL. It would be appreciated if you can help me.
Rolf Okken October 19, 2021
project = yourproject and status changed FROM progress to "code review" order by updated
This maybe the way.
Like Renchuan Xiao likes this
Ollie Guan
Hi @Renchuan Xiao ,
status changed FROM 'in progress' TO 'code review' ORDER BY statusCategoryChangedDate DESC
https://community.atlassian.com/t5/Jira-questions/Order-By-Date-when-an-issue-is-moved-to-a-specific-status/qaq-p/642313
Like # people like this
Hi @Ollie Guan
This is my JQL: project = DEV AND status changed from "in progress" to "code review" AND status = "Code Review" ORDER BY statusCategoryChangedDate DESC
i checked the first of three, it is not order by the time when status changed. Am i write something wrong? Or May the item statusCategoryChangedDate  is not correct?
Ollie Guan
Hi @Renchuan Xiao ,
As mentioned in the post in my previous link, Atlassian Team has not explained more about statusCategoryChangedDate. If you feel that the results obtained after the query are inconsistent with the expected results, you can try other methods, such as
Automation
Send email When Issue Transitioned From In Progress to In Review Then Send email to sb@xx.com
Sort by custom field
Customize a Datetime field. When the status changes from In Progress to In Review, the system records the time, then sorts and subscribes through this field.
Boris Berenberg - Atlas Authority
October 19, 2021
If you need this for only yourself, you can do this as a filter subscription. If you need to set this up for many users, take a look at Notification Assistant for Jira. It's the app we make for sending emails with email templates that match your needs.
Rolf Okken October 18, 2021
Hello Xiao,
You should implement a Projekt Automation  with the Trigger transition and send a email when is happend.
Hi @Rolf Okken ,maybe by sending a email would be better. Could you tell me more about how to achieve this?
If you save a query (search for issues) the topic Details come up. The last topic off Details is subscriptions. Here you are able to define a subscribe with send you all 15 min an update of the filterresult into your mailbox.
An other way receiving Information by mail is Project Automation. Please read this before we start  to discuss this topic. https://support.atlassian.com/jira-software-cloud/docs/automate-your-jira-cloud-processes-and-workflows/
