How to get 'list' custom field options using REST API?
System Admin May 11, 2021
We have different types custom fields. We want to get options for list type fields.
Prince Nyeche
May 11, 2021
First of all, you need to find the field by using the "/rest/api/2/field" endpoint. Then you can use the api for context option to get the options. I'm assuming during the first search, you are filtering for the type of custom field you want.
camus_b_li June 6, 2023 edited
for Jira Server:
If you know the project and the issuetype that the field was used, you can try:
https://{jirahost}/rest/api/2/issue/createmeta?projectKeys={projectKey}&issuetypeNames={issuetypeName}&expand=projects.issuetypes.fields
If you know the issue that the field was used, you can try:
https://{jirahost}/rest/api/2/issue/{issueIdOrKey}/editmeta
Good luck.
Saurabh Kejriwal December 5, 2023
thanks for sharing. works for me :)
D X March 7, 2024
Dear @camus_b_li
thank you for sharing the link, but I got a 404 error when using https://{jirahost}/rest/api/2/issue/createmeta?projectKeys={projectKey}&issuetypeNames={issuetypeName}&expand=projects.issuetypes.fields
I'm sure of the jirahost (using /rest/api/2/field returned all fields), the projectKey and issuetypename
is there another way to list all custom field associated to a project ?
regards,
FREE
