Sign up Log in
How to get thousands separator on custom number fields through smart values/HTML?
Patricia Paguio May 11, 2020
I am currently using Jira automations to send out emails to our workflow and I am having trouble with some smart value formatting in the email's HTML.
  1. Does anyone know how to change the smart value number format so that it shows as 100,000 instead of 100000?
  2. In a multi-line text custom field with wiki renderer, I see that if someone includes an image in the field, it picks it up as an attachment and I'm able to link the user to that image through the attachment link. But is there a way to hide the text referring to that image in the smart value? Please see photos below to view how the image is currently showing in the email.2020-05-12_10-01-02.png
  3. Is there a way to decrease the size of the paragraph breaks for multi-line text using wiki renderer? At the moment, the paragraph breaks are huge and I'm wanting to find a way to customise their size or even switch them to line breaks2020-05-12_10-18-38.png
June 25, 2020
Hi @Patricia Paguio
For your question (1), it appears number formatting was recently added.  This works for commas:
{{issue.story points.format("###,###,###")}}
Best regards,
June 26, 2020
Hi @Patricia Paguio
For your question (3) about reducing spacing, have you tried the smart value Replace() function to see if there are any extra embedded CR/LF that you can remove?  Please look here for information on the function: https://support.atlassian.com/jira-software-cloud/docs/smart-values-text-fields/
Best regards,
