I need your help to get time spent details of linked issues where i can track them only from parent issues. So, I need to track them by parent issues . Please suggest me a best way to do it.
Hello @Srujan kumar
You can try Time in Status for Jira Cloud. This add-on generates 7 types of status time reports.
Get the time spent by Parent using a Pivot table function.
This add-on is developed by my SaaSJet team. So let me know if you have any questions.
Also, you can read more info on how to get the time spent by Parent using a Pivot table function in a short use case.
Hello @Srujan kumar ,
Our team at OBSS built Timepiece - Time in Status for Jira for this exact need. It is available for Jira Server, Cloud, and Data Center.
Time in Status mainly allows you to see how much time each issue spent on each status and on each assignee.
You can use Time in Status with a JQL query below to report on issues that are linked to a specific issue.
issue in linkedIssues("ABC-123")
The app has Consolidated Columns feature. This feature allows you to combine the duration for multiple statuses into a single column and exclude unwanted ones. It is the most flexible way to get any measurement you might want. Measurements like Issue Age, Cycle Time, Lead Time, Resolution Time etc.
For all numeric report types, you can calculate averages and sums of those durations grouped by the issue fields you select. For example total in-progress time per customer (organization) or average resolution time per sprint, week, month, issuetype, request type, etc. The ability to group by parts of dates (year, month, week, day, hour) or sprints is particularly useful here since it allows you to compare different time periods or see the trend.
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well. It supports both Company Managed and Team Managed projects.
Time in Status reports can be accessed through its own reporting page, dashboard gadgets, and issue view screen tabs. All these options can provide both calculated data tables and charts.
And the app has a REST API so you can get the reports from Jira UI or via REST.
Using Time in Status you can:
EmreT
If you would be interested in a mktplace app, to visualize the hierarchy based on the issue links, and track time spent, we have created an add-on to track the progress at each level,
Key features:
Disclaimer: I work for RVS, the vendor for this app, and I am one of the developers in the team
