×Hello,
I have installed the WBS Gantt Chart application and I was wondering if I can completely hide the Task List (left panel). I want to view the Gantt chart in full view without the Tasks on the left.
Dear Panagiotis,
WBS Gantt-Chart doesn't have the function as like hiding the colums.
I will propose an alternative, the columns zone is narrowed by dragging the border between columns and Gantt-bar view.
Or the columns to display in Gantt-Chart are reduced and then the left panel zone can be narrowed.
Hanna,
Hello Hanna,
Thank you for your answer. I was aware about the alternatives but I really wanted to hide the task list completely so I can view the Gantt chart. Thanks for the confirmation. Can you propose any alternative Gantt Chart apps that have the functionality I am looking for?
Panagiotis,
Hello again,
Sorry for reposting after I just accepted an answer but this is the reason I was persistant about this feature. As you can see on the picture the Task list panel has completely gone and Gantt chart is on full view. Is this a bug of I can trigger it somehow?
Panagiotis,
