×The Time Tracking help pop-up text is helpful the first time or three but after that it's just distracting and constantly in the way. How to disable it? (And only show when one hovers over a question or info mark, (?) or (i), that's beside UI elements somewhere).
Hello @Matt Wilkie,
As far as I know you can't disable this message and it appears only on Windows system.
If you use Jira Time Tracking, you might like our app Worklogs Time Tracking and Reports. It's an app that allows you to create custom reports from your Time Logs so, you can easily use it to track your daily Tim Logs and quickly spot where did you forgot to log time. Here is how you can Log Time using Worklogs (without pop-up text ;) ).
Besides that, you can also create reports and answer questions like:
How much time did my team spend on Bugs this month compared to last?
Which issue time took us the most time in project X?
How many hours did each team member spent on specific issue, project, epic etc.?
Or any other question based on Time logged and fields available in Jira issue.
FYI, this also appears on Macs.
The issue is once you learn the formats there's no need to be reminded of them each and every time you go to update the time tracking. And it really shouldn't be required to spend money on a reporting add-on just to avoid the UI annoyance.
Register Now
