How to hide dashboard names to external users
Martin Vali
I have created external user permission rights and the projects and issues are not visible, but all filter and dashboard names are visible
How to hide them?
John Funk
HI Martin,
You will also need to apply permissions to the Filters and the Dashbaords.
Martin Vali
I can't find a place where to change that. Under the edit permission there is non that talk about dashboards
John Funk
Click on Edit for the Dashboard,
Then click the 3 dots next to the Done button.
Then choose Rename and share
Like • Bill Sheboy likes this
Martin Vali
So I have to go over all 200 dashboards one by one?
How to set the default dashboard visibility to certain group?
John Funk
You can't set a default. You can copy one, but I am not sure that would even keep the permissions. You will need to do existing ones manually one by one.
