Hello everyone,
I am trying to do the following:
Actual outcome:
I tried changing the render settings of the field in Jira but the outcome was the same.
I also tried using the "href" option to try and include the text from the field like this: <a href="{{issue.Release Notes}}">{{issue.Release Notes}}</a>
This did nothing and no information from that field was included in the email.
We are sending the email as HTML.
And here is the HTML template we are using:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html lang="en" xml:lang="en" style="font-family: Arial, sans-serif"><head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><title></title>
<!--[if !mso]><!-->
<meta http-equiv="X-UA-Compatible" content="IE=edge"> <!--<![endif]-->
<meta name="viewport" content="width=device-width, initial-scale=1.0"> <!--[if (gte mso 9)|(IE)]>
<style type="text/css">
table {border-collapse: collapse;}
</style>
<![endif]--> <!--[if mso]>
body, table, td {
font-family: -apple-system, BlinkMacSystemFont, 'Segoe UI', 'Roboto', 'Oxygen', 'Ubuntu', 'Fira Sans', 'Droid Sans', 'Helvetica Neue', sans-serif !important;
color: #202020 !important;
</style>
<![endif]-->
.button:hover {
background: #0083C0 !important;
div.issue-key a:hover {
color: #444444 !important;
div.issue-summary a:hover {
color: #0083C0 !important;
span.field a:hover {
</style>
</head>
<body style="background-color: #ffffff; font-family: -apple-system, BlinkMacSystemFont, 'Segoe UI', 'Roboto', 'Oxygen', 'Ubuntu', 'Fira Sans', 'Droid Sans', 'Helvetica Neue', sans-serif; font-size: 14px; font-style: normal; font-weight: 400; color: #202020; letter-spacing: -0.15px; color: #333333; font-family: Arial, sans-serif; font-size: 14px; line-height: 1.4285715; background-color: #ffffff; font-family: -apple-system, BlinkMacSystemFont, 'Segoe UI', 'Roboto', 'Oxygen', 'Ubuntu', 'Fira Sans', 'Droid Sans', 'Helvetica Neue', sans-serif; color: #202020; letter-spacing: -0.15px" bgcolor="#ffffff">
<div class="outer-container" style="width: 100.0%; table-layout: fixed; max-width: 800px; margin: 0 auto; -webkit-text-size-adjust: 100.0%; -ms-text-size-adjust: 100.0%">
<table style="border-spacing: 0; margin: 0; border-collapse: collapse; width: 100.0%; border-spacing: 0; margin: 0; margin: 0 0 0 0">
<tr><td style="padding: 0; padding: 10px 0 20px 0; vertical-align: top;">
<span class="summary">A new software version is available.</span>
</td></tr>
<tr><td style="padding: 0; padding: 0; vertical-align: top; border-top: 2px solid #dddddd; padding:10px 0 0 0">
<div class="issue-key" style="font-weight: normal; margin: 0;"><a href="{{issue.url.customer}}" style="color: #666666; text-decoration: none; color: #666666;">{{issue.key}}</a></div>
</td></tr>
<tr><td style="padding: 0; padding: 0; vertical-align: top;">
<div class="issue-summary" style="font-size: 20px; font-weight: 600; line-height: 20px; margin: 0 0 0 0"><a href="{{issue.url.customer}}" style="color: #0095DA; text-decoration: none; color: #0095DA;">{{issue.summary}}</a></div>
</td></tr>
</table>
<table style="border-spacing: 0; margin: 0; border-collapse: collapse; width: 100.0%; border-spacing: 0; margin: 0; margin: 20px 0 0 0">
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Due date:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.Planned end}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Reporter:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{reporter.displayName}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Status:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.status.name}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666;">Description:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.description}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666;">Release notes:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.release notes.text}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding: 20px 5px 0 0; line-height: 24px; color:#666666">CDNs:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 20px 4px 0 4px">{{issue.cdn}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Priority:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.priority}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Risk level:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.risk level}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Components:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.components for update}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Business Case:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.business case}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding: 20px 5px 0 0; line-height: 24px; color:#666666">Update procedure:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 20px 4px 0 4px">{{issue.work procedure}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Rollback procedure:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.rollback procedure}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Test Plan:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.test plan}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding: 20px 5px 0 0; line-height: 24px; color:#666666">Proposed Schedule:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 20px 4px 0 4px">{{issue.proposed schedule}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Approved Schedule:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.approved schedule}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding: 20px 5px 0 0; line-height: 24px; color:#666666">Customer Impact:</td>
<td style="padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 20px 4px 0 4px">{{issue.customer impact}}</span></td>
</tr>
<tr>
<td style="padding: 0; padding: 0; white-space: nowrap; width: 1.0%; vertical-align: top; padding-right: 5px; line-height: 24px; color:#666666">Component Impact:</td>
<td style="padding: 0; padding: 0; line-height: 24px"><span class="field" style="max-width: 700px; height: auto; display: inline-block; padding: 0 4px">{{issue.component impact}}</span></td>
</tr>
</table>
<tr><td style="padding: 0; padding: 0; vertical-align: top; border-bottom: 2px solid #dddddd; padding:20px 0 20px 0">
<div class="layout-action-button media-print-hidden" style="margin: 0">
<a class="button" href="{{issue.url.customer}}" style="color: #ffff; text-decoration: none; align-items: baseline; box-sizing: border-box; border-radius: 4px; border-width: 0; display: inline-flex; font-style: normal; font-size: inherit; font-weight: 600; height: 2.2857144em; line-height: 2.2857144em; margin: 0; outline: none; padding: 0 12px; text-align: center; transition: background 0.1s ease-out, box-shadow 0.15s cubic-bezier(0.47, 0.03, 0.49, 1.38); user-select: none; vertical-align: middle; white-space: nowrap; background: #0095DA; color: #ffffff; text-decoration: none; font-family: -apple-system, BlinkMacSystemFont, 'Segoe UI', 'Roboto', 'Oxygen', 'Ubuntu', 'Fira Sans', 'Droid Sans', 'Helvetica Neue', sans-serif; font-size: 14px; padding: 0 38px">View ticket</a>
</div>
</td></tr>
</table>
<tr><td style="padding: 20px 0 0 0; padding: 20px 0 0 0; vertical-align: top; font-size: 13px;">
<span class="summary">Reply to this email or update release ticket in order to adjust scheduled time for update.</span>
</td></tr>
<tr><td style="padding: 0; padding: 20px 0 20px 0; vertical-align: top; font-size: 13px;">
<span class="summary">Best regards,<br>United Cloud Team</span>
</td></tr>
</table>
</div>
</body>
</html>
Hi @Danilo Simic To render HTML, add .html to the end of a field. For example, {{issue.description.html}}
This did the trick. In the HTLM template I added the ".html" and everything was sorted out.
I was so focused on encoding and somehow including a link that I did not try this simple solution. Thank you very much.
Maybe one thing to note for others. The render style of the fields was left on Wiki style. Not sure if this also affects the links in the email.
Save your spot
