Hello community!
Can you please help to understand if integration between SVN and JIRA Software is possible and how?
Any link would be really helpful.
You can use Atlassian Fisheye for this, but it is discontinued and relatively pricey for what it does.
Hi @NSantagostino,
Welcome to the Atlassian Community.
There is only one app that I found on Marketplace that allows you to integrate SVN and Jira Software Cloud, Svn Gateway - Subversion links in Jira.
