We are wanting to experiment with working w/ one of our clients in our Jira instance. We have created a role to lock down ability to browse, create, and view company managed JSWs, and have a game plan for team managed JSWs. However, an external user is still able to view filters, create issues, view dashboards, and use all other areas of the top bar (see attached). What is the best way to lock down our instance so that our client can come in and only see the project we are giving them access to and not use the top bar located in attachments?
Thanks.
Hi @JD Lobue and welcome to the Community!
You cannot disable the navigation bar in Jira Cloud. It is the map for anyone with a license to the product to find their way around in the product.
However, all the items can be restricted:
Hope this helps!
Save your spot
