How to make a Jira field mandatory?
Rohit Vohara
November 5, 2021 edited
Hello Community,
I came accross to find an solution to make approver field mandotory on issue screen.
And It should have description like, Please Enter Approver Name. Need an help to configure this.
Tnxs- Rohit
11 votes
Mayur Jadhav
Hi @Rohit Vohara ,
Welcome to the Atlassian Community!!!
For Making field required you need follow this steps:
1. Go to the Project setting> Summary.
2. Search for the Field configuration scheme and select it.
3. New window will open and search for the desired field such as Approver.
4. At right side their will be Edit, Hide, Required and Screen options.
Edit---> To set the description
Required---> To Make the field Mandatory.
Please let me know if the answer is helpful or for any queries, or questions.
Mayur
Rohit Vohara
November 5, 2021
Hey Mayur,
Thank you for your quick reply 🙂
The provided solution works for me, Thanks
Like • Mayur Jadhav likes this
Mayur Jadhav
I am glad that the provided solution works for you, Please hit the Accept button Means it will help others too!!!!
Like • 2 people like this
Richard Hosier January 5, 2022
Hi there
I am looking to do the same.
I tried this and got to item 3 - and the field at the end on the right just says - "82 screens" - I do not have Edit Required Etc.
Any ideas?
Thank you
Like • Emma Chilman likes this
Kari
Hi @Mayur Jadhav
I am looking to do the same, with the difference that I do not want to make the field mandatory for all the Projects.
I want to make just a few default fields like Components and fix Version as mandatory field in a specific Project. How  do I have to proceed?
Thank you
Like • 4 people like this
And what if I don't have "summary" to enter? Screenshot 2022-05-18 140151.png
Mayur Jadhav
Hi @Zuzanna Kraszkiewicz-KrzemiÅ„ska ,
The Solution which I have provided above is for Company Managed Project. Their might be little difference as compare to Team Managed Project.
Mayur Jadhav
Hi @Richard Hosier
In that case you need to have make separate field configuration scheme for those project which you want to make fields mandatory i think.
Mayur
Hi JIRA experts! @Mayur Jadhav I see what you're saying about the difference between Company Managed projects and Team managed ones. Nevertheless I need to find a solution how to make fields mandatory for my issue types - otherwise the process will not work and I don't have a tool to make people accountable to fulfill all fields. Please, could you provide any more guidance?
Thank you and have a great day!
Zuzanna
Mayur Jadhav
Hello @Zuzanna Kraszkiewicz-KrzemiÅ„ska
As of now, this feature is not available in Team managed project, Atlassian is working on it, and maybe they will release it in an upcoming release, you may please follow and vote on this ticket, so when they release it, it will notify you.
Hope this information is useful.
Mayur
Thank you!
tjwood
@Mayur Jadhav massive companies don't let their employees create their own schemas. If a feature can't be done within an existing schema, we're completely stuck.
Like • Molly Simoneaux likes this
Hardikkumar Patel
June 5, 2023
@tjwood you can do it using validator on workflows for the project (ie. on "Create" Transition) . But this will also require a separate workflow for the project.
amrita mishra
August 31, 2023
Hi, can i make a certain Jira field 'Required' for an assignee
Chaya Adams January 28, 2024
I'd also like to know how I can make a field 'required' i.e. required to have a parent. Thanks @Mayur Jadhav
