How to make a component field to be required based on different filled custom field? (Jira Cloud)
Sagi Gueta
Hey,
I'd like to make a change in my Jira that will cause Component field to be required just if "bug report" field is filled.
As I read already, unfortunately, it's not possible to make it by using ScriptRunner.. Additionaly, I don't want to make a new WF for that matter as we already using to many workflows.
Is there any option to do it by Jira tools?
Jack Brickey
January 31, 2022
there is no OOTB solution to optionally require a field be updated based on another field being edited. you could use automation to update the Component based on the value entered in the other field.
