How to make a custom field on isssue screen visible readonly and only programmatically updatable
Smita April 16, 2019
I want to have a custom field on JIRA issue to be visible on all screens ( Edit/View) but it should not be editable by end JIRA user .
I want to set the value during creation programmatically ONLY and then it should just be visible to user
How can this be achieved using OOTB JIRA Cloud Funcrionality. Kindly help
Tarun Sapra
April 16, 2019
Hello @Smita
What you want is not possible "OOTB JIRA Cloud "
Also, why do you want the custom field to be available on the create/edit screen and still not being editable? Isn't it just going to confuse the user?
What you want can be somewhat achieved using scripted field which are not fully supported yet on cloud.
Please see this question
https://community.atlassian.com/t5/Jira-questions/Is-there-any-way-to-create-calculated-fields-in-JIRA-Cloud/qaq-p/231346
http://scriptrunner-docs.connect.adaptavist.com/jiracloud/script-listeners.html#_run_as_user
Tarun Sapra
April 16, 2019
What I suggest to you, is to have a custom field only on the view screen and give the ability to the user to update it via transition screen or have some login in place to update the field via transition post-function.
Hi Tarun, this field represents a customer support number that becomes available automatically during the issue creation and we don't want that to be editable by user directly. It should always be put or stamped on the issue at the time of creation and that too programmatically .
Tarun Sapra
Based on your description, it's best to use a custom field and have it only on the view screen of the issue and update the value of the field programmatically via the post-function of the create transition.
Like Smita likes this
When I hide it from Create/Edit Screen - the programmatic access fails. I always thought screen is just a representation of an issue type but looks like its a class that the programmatic access uses to create an issue object , so when I don't have the field on create screen - the rest API fails..... I am not sure how we could restrict this.
I also thought if we could have issue action level permission to be given to certain users - which looks to be possible using Validator BUT then this cannot be restricted to a certain issue type .
Any suggestions?
Tarun Sapra
April 16, 2019
Hello @Smita
If you are using REST API to update the field, then you need to field on the edit screen while updating and create screen while creating issue.
Since Jira doesn't have field level permission hence this is an open ticket for jira cloud, wherein you can hide the field for specific groups/roles
https://jira.atlassian.com/browse/JRACLOUD-69298
If using Atlassian SDK , is that possible? I am not sure ..asking
Tarun Sapra
April 16, 2019
Atlassian SDK is for server platform, for cloud platform it's Atlassian connect.
https://developer.atlassian.com/cloud/jira/platform/integrating-with-jira-cloud/
Tarun Sapra
April 16, 2019
Hello @Smita
If you feel my answer has helped you, please accept/upvote so that others are also helped. thanks.
Smita April 18, 2019
hi Tarun, I found a simple way to do it. Let me share it
