How to make released items disappear from my next-gen Kanban board
Terri Paik March 20, 2020
We are using a next-gen Kanban board, and issues were piling up in the Done column and making the board huge. So based on answers in this forum, I added the "Releases" feature and assigned all of our done items to a Fix Version, and then released that version. However, the tickets are still appearing in the board.
Some people in other posts are saying to edit the board's sub-folder or query, but I do not see any way to do that. I do not see any "Board settings" or "Configure Filter" on this board. Any ideas?
I checked and my Done tickets are only assigned to one Fix Version each and that Fix Version has been released.
There must be a way to make the clutter go away.
Thanks so much!
2 accepted
John Funk
Hi Terri,
There's no way to do a release right now.
If you want a release option in next-gen, vote for this idea:
https://jira.atlassian.com/browse/JRACLOUD-70916?jql=text%20~%20%22next-gen%22
and
https://jira.atlassian.com/browse/JRACLOUD-70914?jql=text%20~%20%22next-gen%22
Issues in the Done column will be automatically removed from your board after 14 days.
You can find more info here:
https://confluence.atlassian.com/jirasoftwarecloud/get-started-with-next-gen-boards-945104903.html
Terri Paik March 22, 2020
Thanks @John Funk for the info that they'll disappear after 14 days.
I'm not sure what you mean by "There's no way to do a release right now." I enabled Releases in my project, and then created a couple versions, and assigned my done stuff to a version, and then I was able to "Release" the version. It's just that those tickets are not disappearing from my board.
John Funk
Hi Terri - Yes, that's what I meant - normally a release in a Classic project removes the tickets from the board. But not in Next-gen.
Like Terri Paik likes this
John Funk
If that's all we can help you with right now, can you click on the Accept answer button above to close this one out? Thanks!
John Theofanopoulos March 21, 2020
Well, I had a look and I didn't find any options for next-gen projects to edit the board query etc.
A simple way is to move the task into the backlog.
If a task is done it won't be showing on the backlog and you can always retrieve it in the release tab.
Thank you, hmm, that would be a workaround but it seems pretty strange because my items are done and shipped, and they aren't really my backlog at all.
Learn more
