×Hello
we are trying to make specific fields non-editable at a particular workflow status in jira cloud. How can we achieve this using ScriptRunner.
we are aware of setting WF properties & removing the particular field from issue edit view and to add self transition to edit that particular field to all statuses except desired status
looking forward to know how to achieve this via ScriptRunner via listener.
Scenario :
If i wanted to make component field non editable at a transition called "QA Review" from status In-Progress to In-Review. How do i do that
Thanks in advance
Hi!
In Scriptrunner on Server / DC you would be able to do this using behaviours with a guid workflow.
On Cloud unfortunately you can't, the app simply isn't that far yet on Cloud, but new features are being developed and added.
Your best bet to get this to work in Cloud would be as you mentioned: Make the field editable only on a tranistion.
Jeroen
Noted ! Thank you @Jeroen Poismans
is it not possible with the new script runner behaviours for Jira cloud ?
Behaviours on Cloud only works for a few types of custom field, and only on the create screen at the moment (not view or transition). We're working on it.
See https://docs.adaptavist.com/sr4jc/latest/features/behaviours
