How to make the system field mandatory.
kanaka prasad ponnuru
Hi Team,
I have a requirement from my client that Fix version(System field) should be mandatory.
I know the process of making a custom field mandatory from field configurations but I don't know how to make system field mandatory
Can someone guide me how to achieve this without any code?
Regards.
Kanaka
Mikael Sandberg
March 9, 2021
System fields can also be controlled from the field configuration, not just custom fields, so you could make fix versions required in the configuration. But if you only need it on specific transitions then the solution that @John Funk is suggesting would be the way to go.
John Funk
March 9, 2021
Hi @kanaka prasad ponnuru  - Maybe add it as a required Validator in the workflow on the Create transition?
