How to manage three boards on a company-managed project?
Emily Calero December 12, 2022
We have three boards on a company-managed project and we need each board to capture the requirements for each product that we're working on for the same client. All the requirements are in the backlog of the project but we  don't know how to add the requirements (user stories and tasks) to each board, each board should have different requirements because the products are different. Is there a way we can add a set of requirements (user stories and tasks) to a board and then add another set of requirements (different from the first set) to our second board?
Samet Yildiz December 12, 2022
Hello Emily,
what type of boards do you use?
When you are using Scrumboards than you must start a sprint otherwise you will not see any tickets on the board.
Apart from this each board represents a filter behind it.
You can easily build a new filter eg. project in (ab, abc) and type in (task, bug).... so that only certain projects and issue types are displayed on the board.. and another for the other board..
Read the story
