How to migrate data from one custom field type to another one
suren December 6, 2022
we need to change the type from single user list to multiple user.
Sebastian Krzewiński
Hi @suren
There is no easy way to do that. Options that I see:
- you can write a script based on Jira REST API and copy values from one field to another one
- you can use automation for jira and create a rule that will be copying values based on JQL
- you can use some add-ons like JSU, JMWE and create a transition where you will use post function that will be copying values.
Seba
Thanks a lot @Sebastian Krzewiński
