Hello!
The company are using Youtrack ad want to go to Jira. How to migrate tasks from Youtrack to Jira?
I`ll be very thankful if you could help!
You can export your YouTrack data to CSV to import it to Jira.
In order to create a CSV file you need to select the Issues in CSV option from your reports menu in YouTrack. Make sure to prepare the search criteria first so that exported data set is exactly what you want to have imported into Jira. Save the resulting CSV file.
https://support.atlassian.com/jira-cloud-administration/docs/migrate-from-other-issue-trackers/
You could download the issues into a csv ( https://www.jetbrains.com/help/youtrack/standalone/export-issues-csv-excel-format.html) and then import them into Jira from there.
You will need to explore how to map the Fields but it should be a quick way to add them all when you're happy with the import process. (https://support.atlassian.com/jira-core-cloud/docs/create-issues-using-the-csv-importer/)
this does not export parent/child relationships of stories and epics
On a more adventurous road, you may try https://github.com/mogic-le/youtrack-to-jira or https://github.com/agapoff/Lumper
Hope this helps!
