I am using AIO Tests to QA a project, and wonder if there is any way to:
Thank you,
Hector
Hi @Hector Chen
AIO Tests exposes a Get Traceability REST API (https://tcms.aiojiraapps.com/aiotcms-static/api-docs/#/Traceability/getTraceabilityForRequirement), which can help you look at the latest results of all cases linked to story. Using the case status details from the AIO API, you can call the Jira API to update the status of the ticket.
AIO Tests also has a Jira Panel, which shows the latest run statuses of all cases associated with a story, which can give a direct view of whether all linked cases are passed or not and can help you make a decision right in the Jira Story.
If you have a suggestion or a feature request or if you would like to discuss this further, please reach out to us via our support portal or book a slot at your convenience.
Noopur - AIO Tests Team
Save your spot
