Hi community!
I'm trying to multiply these 3 field values:
The rule is triggered when the field Ease is filled up. All of them are numeric fields.
This is the current formula that I'm using but it is not working:
{{#=}}{{issue.customfield_10083}} * {{issue.customfield_10087}} * {{issue.customfield_10088}}{{/}}
Below you can see how I'm trying to set this up:
Does anybody have a clue?
Thanks in advance,
Vitor
Hello @Vitor Seabra
What is your evidence that it is not working?
What does the Audit Log show for the execution of the rule? Is the rule being triggered? Is there an error message? Are you seeing no update to the field, or is it updated with the wrong number?
Can you add Log action step(s) to print the value of each custom field to the Audit Log to confirm you have referenced the correct custom fields?
Hello @Vitor Seabra
Can you share with us the solution to your issue?
For some reason the same querie started working properly. I basically haven't changed anything.
Hi @Trudy Claspill ,
Could you please share the issue where you are facing the issue..?
give me some your opinion below.
Thanks & Regards,
Sanjen Bariki
I am not the person who posted the question. It was posted by @Vitor Seabra .
