How to perform reindexing on all nodes and how to copy index snapshot
Jyoti Kumari
Hello Everyone,
How we can perform reindexing on all nodes, so that only one node will be in maintenance mode and other 2 node should be active.How we can copy index snapshot from one node to another node, once indexing completed on one node.Kindly share API to implement through groovy script.
Thanks and Regards,
Jyoti
Salih Tuç
December 29, 2024
Hi @Jyoti Kumari ,
First of all, you need to connect from the desired node (Let's say node1). Make sure that you made node1 separate (via disabling reverse proxy or removing it from node balancer, etc.) so that no user can access to the node1.
Then, you can start the reindex from the node1; from System -> Indexing menu. Make sure you select the "Lock the system" option because otherwise the reindexing will take too much time. While the reindexing continues, there will be no access to node1 from other users. (You are removing node1 from load balancer because of that).
When the re-indexing finished, you can re-open the node1 for user access. After that, you need to copy the index from node1 to other nodes (you can add a Job to the system or you can do it manually).
For more context, you can check the related documentation from here.
Sunny Ape
December 29, 2024 edited
Or, alternatively, @Jyoti Kumari , you can just Google:
  1. jira data center re-index nodes
  2. jira data center copy index between nodes
  3. jira data center rest api start indexing
and then read Atlassian's existing documentation on these frequently asked questions yourself
Sunny Ape
December 29, 2024
Hello @Salih Tuç
You don't need to do that, as the active nodes automatically re-sync their indexes to the one that has had the full re-index done on it.
Copying indexes from one node to another is a special case, and only used in very specific circumstances.
SERVER
VERSION
9.12.15
atlassian, team ’25 europe guide, teamwork collection, atlassian events, conference guide, team culture, collaboration tools, ai in teamwork, atlassian learning, event schedule, keynote previews, community events
Must attend events for Team Europe '25!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
