How to prevent Tempo-Timesheets from taking over "Time tracking provider" setting?
georg.sterz April 10, 2020
Hi folks,
we are using Jira Cloud + Tempo-Timesheets plugin.
We like to have "JIRA provided time tracking" as default time tracking provider.
Problem is, that every week or so, somehow Tempo-Timesheets "takes control" and sets itself as default time tracking provider for issues.
Any ideas how to prevent this?
Thank you so much,
Georg
Brant Schroeder
Georg,
  This sounds like a bug and I would suggest submitting a ticket to tempo support.  Sounds like everytime an update occurs to the temp application your settings are changed back to tempo. At least that is what I am assuming is happening.  You can contact tempo support here: https://tempo-io.atlassian.net/servicedesk/customer/portal/6/user/login?destination=portal%2F6
georg.sterz April 21, 2020
Thanks Brant, will submit an issue report to Tempo.
shiqiqi
March 30, 2023
hi, I wondered if any updates from Tempo official? We met the same bug. the time tracking is switched to Tempo intermittently and quite annoying.
Kristine Shahnazaryan September 22, 2023
the same for me now
Brant Schroeder
@Kristine Shahnazaryan you will need to submit a support ticket with Tempo
Keaton Babb
December 13, 2023
@Kristine Shahnazaryan @shiqiqi
I am having the same issue. Have you logged a support ticket with them?
Alex Neskin
December 14, 2023
The same problem. Is there any resolution from the Tempo team?
Learn more
