How to re-create a report (pic attached) : Avg resolution time/Total Resolution Time/Issues Resolved
cameron.conover May 9, 2019
I created a dashboard a few months ago, and took a screenshot of part of the report (see below).  Now I'm trying to find it, and can't.  Nor can I re-create it......HELP!!
Coley Anderson
May 9, 2019
Hi Cameron - I think you need to look for the "Resolution Time Report"
That is the report that matches the Data Table you posted, is this what you are looking for?
That's it!!! Thanks soooo much.
Like • Coley Anderson likes this
