How to remove helper text from migrated fields?
Carlos Henriques
In December we migrated our Jira Server instance to Jira Cloud.
With the migration process, all the form fields, custom, and system, started displaying a helper text with the date of the migration. I can edit the description of custom fields to remove this helper text, but I can't find how to do it for the system fields.
Screenshot of the problem below:
These messages have no value at all and just make the form busier.
2 accepted
Pavel Junek
February 3, 2022
Hi Carlos,
I assume this text was made by the Atlassian Cloud migration assistant. A similar topic was addressed here. You will need to edit the Field Configuration.
I pressed the cog in the top right corner and selected "Issues" to get to the Admin section. From there I selected "Field configurations" in the Fields section of the left hand menu.
I had an item called "Default Field Configuration (migrated) which had Field Configuration Schemes associated with it. I clicked "Configure" against this (not Edit).
The next screen listed lots of fields, some of which showed the "Migrated on XXXX" text. I found I could edit this text and remove the unwanted characters.
Pavel
Carlos Henriques
Yes, this was added during the migration using JCMA.
Thanks for pointing out that this can be removed in the Field Configuration, I didn't remember that the descriptions could also be changed there.
Like Pavel Junek likes this
Sika
September 27, 2023
Is there any automated way to do this?
Like # people like this
Rilwan Ahmed
February 3, 2022
@Carlos Henriques
For custom fields, you can remove it from Field configuration section
Piyush A (STR)
July 9, 2023
Hi, actually there's  only way to remove it using the database call.
But we have a process to remove those, created by me in our organization.
If required, we can connect over linkedin to remove those migrated on from Notification  scheme, workflows, workflows schemes, custom field, field config, etc.
We did that and it took 1 hour than actual 2 days of manual work by 2 persons.
nojansen April 13, 2022
I don't see the point of adding the "Migrated on" to each field description! We are evaluating migrating numerous large projects to Jira Cloud. Manually edit the description of EACH field for EACH field configuration will be EXTREMELY time consuming!
Surely there must be another way? Or a way to prevent JCMA from adding it the field descriptions?
Todd Springett
August 16, 2022
I agree. We have 48 pages of fields with the migrated note. We need a way top remove those in bulk!
Piyush A (STR)
July 10, 2023
Actually we can. We have developed a in-house app for the same. If required, we can connect over LinkedIn to help you with the data.
Samuel Lerch
Hi @Piyush A (STR) Just saw this answer here - can we discuss the solution you developed? Would be a big help for several customers.
My LinkedIn is simply Samuel Lerch
Happy to talk about a possible solution! :)
Best regards
Samuel
