×Hi ,
I am using JIRA python to update to issue link(duplicate link) for JIRA id and it works fine.
Now i want to remove those issue link from that JIRA id
Any Idea pls
I am able to do in using below code
#getting issue links
#create JIRA instance
self.jira = JIRA(basic_auth=(self.jira_username, self.jira_api_token), options={"server": self.jira_server})
#Pass JIRA name and get Issue links
idl=self.jira.issue(jiraid) # passing JIRA name
getIssuelinks=idl.fields.issuelinks #issuelinks
#iterate and delete
for x in getIssuelinks:
print(x.id)
self.jira.delete_issue_link(x.id)
Could you clarify :
Since id1 is a dictionary this does not work,
I should be doing something wrong.
My Code:
from atlassian import Jira
import json
jira = Jira(
url='https://aa.bb.com/',
token='someToken')
issueData = jira.issue("BBBB-1000")
json_formated= json.dumps(issueData, indent=1)
getIssuelinks=issueData.fields.issuelinks #issuelinks
print(json_formated)
Error:
Traceback (most recent call last):
File "C:\Data\repositories\jira_python\jira\jira_test.py", line 9, in <module>
AttributeError: 'dict' object has no attribute 'fields'
It's a bit late, but as the above helped me, here is my code to remove all links within an Epic.
epicKey = input("Enter the Epic key")
jqlStr = f'issueFunction in issuesInEpics("key = {epicKey}") OR (type = Epic AND key = {epicKey})'
fields = ['key', 'issuelinks']
issues = jira.search_issues(jql_str=jqlStr, fields=fields, maxResults=1000)
for issue in issues:
links = getattr(issue.fields, 'issuelinks', [])
for link in links:
try:
jira.delete_issue_link(str(link.id))
print(f"inwardIssue link {link.id} deleted")
except Exception as e:
print(f'Failure removing links using delete_issue_link: {e}')
Learn more
