How to remove "Create Issue" modal when creating an issue from backlog view: "+ Create issue"
Glenn.N
December 6, 2023
Context:
  • Company managed project
  • Backlog View
  • Two separate scrum boards (single project)
    • 1st board:
      • Select "+ Create issue"
      • Can enter inline text on the backlog view
    • 2nd board:
      • A "Create issue" modal appears
Question:
  • How do I remove the modal from the 2nd board please?
Thanks in advance!
GN
Glenn.N
December 6, 2023
Found the issue.
The 2nd board (general settings) was using a saved filter that was referencing a field that no longer exists. By updating the filter to the correct field, it now works as expected.
lrdnathanview
April 10, 2024
I have a similar problem but its affecting all my boards. Does this mean I have a field across all boards that probably doesn't exist anymore? Also, I'm only using default filters.
