How to restrict workflow transition screen based on custom field value
U April 25, 2016
New transition screen that has been configured should be popped up based on the custom field check box named as “Exists in Production”
  • If “Exists in Production” is selected then this transition screen should appear upon clicking on the workflow transition “Start Fixing”.
  • If “Exists in Production” is not selected then workflow transition should be processed upon clicking on “Start Fixing” without this screen pop-up.
Can you suggest implementation methods for this.
Nic Brough -Adaptavist-
April 25, 2016
Create two transitions
  • one with a condition of " 'exists in production' is empty" and with no transition screen
  • one with a condition of " 'exists in production' is  not empty" and with the transition  screen
