How to set a default priority for a company-managed project without impacting the default priority for the rest of the company-managed projects?
Hi @Nicole Qu ,
Go to that particular workflow
Step:1
Click on create transition.
Step:2
Click on postfunctions
Step:3
Update Issue Field >> IssueField:Priority, FieldValue:High(select what do you want)
Add it.
Publish that workflow.
Manmadha
