How to set a length size on a custom field using scriptrunner behaviour in Jira cloud
Jyoti Mane
I'd like to set a size in a custom field. I need allow only 65 characters
Vando Goncalves (e-Core)
May 4, 2023
Hi @Jyoti Mane
Just to confirm, you're using Behaviors for Cloud, right?
I'm not sure if you will be able to do that, but other possible option would be using validators and setting this restriction in the create transition.
Go to Project Setting > Workflows
Edit the workflow for the affected issue type
Switch to Diagram mode
On Create transition, click on the Validators
Choose Add Validator > Regular Expression Check
If you would like to restrict the field to a specific length:  enter [0-9]{n}$
(n) reflects your desired field length.
You just need to set this on the required workflow transition (ideally after the initial field input is required)
(Originally posted here: https://community.atlassian.com/t5/Adaptavist-questions/How-do-I-set-a-character-limit-on-a-custom-field-using/qaq-p/762038)
Joel Batac
try this
def formField = getFieldById('customfield_XXXX')
def value = formField.getFormValue() as String
//formField.setAllowInlineEdit(false)
    if ((value).length() > 65 ) {
        //formField.setRequired(true)
        formField.setError("Max number of characters is 65")
    } else {
        formField.clearError()
Jyoti Mane
Thanks @Joel Batac
This code did not work in ScriptRunner Behaviours for JIRA Cloud.
Nic Brough -Adaptavist-
May 4, 2023
I'm afraid Jira does not yet support SR's abilities to do a lot of things in Cloud, but we are working with Atlassian to try to get this sort of stuff added.
Like # people like this
